Possibility to combine more models together
All projects we do in BIM are separated to more models (HVAC, MIP, etc.).
It would be great to have the possibility to combine and see them in one view.
Thanks and have a nice day!
7 Comments
Bud_Schroeder_ADESK
Autodesk Support
Thanks for posting this Idea, we will flip it to Under Review. Be sure to add your own comments to this to let us know how you would like to use this as a feature in A360 and also be sure to vote for it. We want to get an idea of how many people would be interested in this as a feature in A360.
Thanks for submitting your Idea.
To specify the usage of this future:
1) I have a building model
2) I have other models such as HVAC, static, elektric and others
3) I would like to combine them together to see the building model with some of the others
It is not about clash detection (but it would be nice future as well 🙂 ) but about seeing the building all together.
torresleon.arq
Yes, this please!
It would be great. It is very needed in the Project coordination.
r.janssenLWABH
In my opinion this is already possible....
1) Make sure all files (your own rvt file, rvt-, and dwg links and eventually image files if you made custom materials) are in one and the same map.
2) Dont put any other files in this map.
3) If you had to replace links (because they were in different maps) make sure you relink them from the new created map.
4) Go to your A360 account and choose as upload: assembly.
5) Choose the map were you put all the files to upload.
6) Choose your own rvt file from the dropdown menu as the parent file.
7) Sit back and wait while the files are uploaded.
Make sure that all the rvt files/links aren't cropped with section boxes in the mayor 3d view.
Hope this solution works for you. It did for me.
Thank you very much!
I thing the tool wasn't there...
Actually it didn't work really when I tried that, the models hadn't
combined together,
but there is maybe some my mistake.
Did you meant "folder" by "map"? If not, what do you mean by it?
Thanks a lot once more!
Matyas
r.janssenLWABH
Yes bij map i ment folder.... I changed it also in my First reaction
