Profile settings > Manage projects >active column
In my opinion the information in this column is confusing. In this column all the pojects that have the status "Active" will show a toggle "Deactivate" to deactivate them.
But at the first glance when you see the table as a novice user, you think that all the projects are deactivated by default (because in the column you read "Deactive" no?).
In my opinion the text in the column should not show the function you can use to toggle the actual status of the project but should show the actual status itself.
So when a project is "Active", you should read in the column "Active". When you click on "Active" the project will be deactivated and in the column you should read "Deactive".
Johan
