Are Project Contributors considered to be part of the Subscription costs?
Or, can users with a free A360 Team account be invited into a Project as a Project Contributor at no cost?
Solved by Bud_Schroeder_ADESK. Go to Solution.
Thanks. Looks like I looked over the unlimited Project Contributors part.
So my question regarding adding these PC users still stands.
If I have a consultant/contractor who has a free A360 can they be linked into a Hub Project as a PC, or do they need a new account created in the Hub?
Hi Chad,
You have to invite the PC to your Team Hub. This is much like how it works with the Tech Preview. If I have a project called Chad and I invite you to Chad, then that is all you can see is the Project Chad. What a PC can not do is see other projects and be an administgrator.
A Project Contributor can access only the projects that he/she has been invited to. He/she can invite other contributors (pending approval from Project Moderator). A Project Contributor cannot be made a moderator, cannot see other projects in the team or who team members are and cannot share or create public links in the project without approval.
Hope this helps.
