A360 Drive Forum
Welcome to Autodesk’s A360 Drive Forums. Share your knowledge, ask questions, and explore popular A360 Drive topics.
What is replacing A360 Desktop
10 REPLIES 10
Message 1 of 11
4903 Views, 10 Replies
Is there anything replacing the desktop sync for A360 Drive?
10 REPLIES 10
Message 2 of 11
scott.a.green
@Anonymous
Autodesk Desktop Connector replaced A360 Desktop (for Drive - it is retired as of 6-19), it ties into BIM 360 Team and BIM 360 Document Management. That being said, the A360 Drive service is being replaced by Autodesk Drive
Please let me know if that explanation helps.
-Scott
First Name Last Name or First Name.Last Initial
Public Facing Job Title
Link Name | Link Name | Link Name | Link Name
Message 3 of 11
in reply to: scott.a.green
Thanks Scott. I guess I'm wondering if I need to download so I can get the
Autodesk Desktop Connector up and working?
Message 4 of 11
scott.a.green
@Anonymous
See: Download Desktop Connector
See Also:  To Install Desktop Connector for BIM 360
-Scott
Message 5 of 11
@Anonymous
I haven't heard back from you and wanted to see if my posts had helped to answer your inquiry or if you had any follow up questions for me - if not, please mark the appropriate post with "accept as solution". This will improve findability in case other users are searching the forums regarding a similar question or issue.
Thank you,
-Scott
Message 6 of 11
So If I understand this correctly, I need to purchase BIM 360 team or BIM
360 Doc and then use the desktop connect to get the files on my computer to
sync to the cloud now?
Message 7 of 11
scott.a.green
@Anonymous
Yes, the very latest version of the Desktop Connector (+ the BIM 360 Docs plugin) will allow you to sync to BIM 360 Team and BIM 360 Document Management . It will display a list of your Team and Docs projects and so will allow you do upload the files to the projects.
-Scott
Message 8 of 11
@Anonymous
Please let me know if my responses helped to answer your inquiry, if so, please mark the appropriate reply with
"Accept as Solution".
Thank you,
-Scott
Message 9 of 11
What is replacing the mobile side of A360 though?
Message 10 of 11
scott.a.green
@Anonymous
See:  A360 Drive: How to share files from cloud to a mobile device?
"There is no specific A360 Drive application specially designed for mobile devices. ".
-Scott
Message 11 of 11
Hello @scott.a.green ,
Thank you for the response and I'm sorry to be a broken record however, is A360 officially shut down? The reason I ask is that I was still able to create a A360 cloud space. Please confirm for me as we have a client that currently uses A360 and they need to know what there next steps are.
Thank you Smiley Very Happy
Technology Administrators
