Is there anything replacing the desktop sync for A360 Drive?
Solved by scott.a.green. Go to Solution.
@Anonymous
Autodesk Desktop Connector replaced A360 Desktop (for Drive - it is retired as of 6-19), it ties into BIM 360 Team and BIM 360 Document Management. That being said, the A360 Drive service is being replaced by Autodesk Drive.
Please let me know if that explanation helps.
-Scott
@Anonymous
See: Download Desktop Connector
See Also: To Install Desktop Connector for BIM 360
-Scott
@Anonymous
I haven't heard back from you and wanted to see if my posts had helped to answer your inquiry or if you had any follow up questions for me - if not, please mark the appropriate post with "accept as solution". This will improve findability in case other users are searching the forums regarding a similar question or issue.
Thank you,
-Scott
@Anonymous
Yes, the very latest version of the Desktop Connector (+ the BIM 360 Docs plugin) will allow you to sync to BIM 360 Team and BIM 360 Document Management . It will display a list of your Team and Docs projects and so will allow you do upload the files to the projects.
-Scott
@Anonymous
See: A360 Drive: How to share files from cloud to a mobile device?
"There is no specific A360 Drive application specially designed for mobile devices. ".
-Scott
Hello @scott.a.green ,
Thank you for the response and I'm sorry to be a broken record however, is A360 officially shut down? The reason I ask is that I was still able to create a A360 cloud space. Please confirm for me as we have a client that currently uses A360 and they need to know what there next steps are.
Thank you
