Hi there community,
Hopefully a quick one. I'm using A360 Drive to share a model with a client for viewing within the browser, slight issue, when viewing / navigating the model in first person model i can not seem to get off the ground and into a 'fly mode'.
I'm looking for a way to get onto/above the roof, or generally another level of my building without needing to go through the front door and up the stairs, only to walk through a wall and fall to the ground.
In the past i have used A360, which works fine, but just trying to use A360 Drive to get around A360's limitations (5 no. maximum projects etc.)
Any help much appreciated.
Solved by bogdan_ciobanu. Go to Solution.
Thank you for your question!
After selecting the First Person mode, use the Q and E keys to go down or up. Let me know if this helps.
Also, check this article: Using A360 Viewer Tools to learn more about the viewing tools we have in A360.
If my post answered your question, thank you for clicking on Accept Solution, so that other community members will find it and benefit from it easily.
Thank you!
Best regards,
Bogdan
Thanks Bogdan,
This is great! What would be perfect is if there was a way to disable 'release key to land on nearest floor'.
I assume this is not possible? I'm trying to achieve the attached view without needing to hold/constantly tap the 'E' key.
Thanks for your time with this.
Regards
Ruhit
Glad to hear it helped.
You are correct, I am afraid there is no option to change/edit the behavior of the navigation tools.
Thank you for taking the time to click on Accept Solution for the post that answered your question to help other community members to find it easily and benefit from it.
Best regards,
Bogdan
