I uploaded a model to A360 Drive and nothing shows up, and it's been loading a view all day with no results. I watched the YouTube video "What is A360 Drive?" and you can see the obvious difference between how theirs and mine.
I noticed theirs actually has a section for "Model" where you can view doors, windows, pipes, walls, etc. Mine only has "3D View". The plane Jane sheets wont even load
Solved by patrick.beattie. Go to Solution.
Your most recent reply is separate from the original question for which this forum post was started. I will be moving this post into a separate thread within the forum.
Don
Hi @ben,
Thank you for posting to the A360 Drive forum. I can see that your model is not appearing in the viewer after uploading.
Does this happen for all of the models you have tried to upload, or only a particular model?
A360 Drive may have trouble processing your particular model, but we would need to gather some more information on it. What is the authoring software of the model and does it contain any referenced/linked models.
If possible would you be able to send me a Private Message with a Public Link to your A360 Drive model?
Let us know if you have any questions. I look forward to your reply.
Best regards,
Patrick B.
Global Product Support
I have only tried upload two projects to A360 Drive. The first one was a tiny little one as a test run, that showed up just fine, it was only 63MB. This one is much larger at 120MB.
I do have Arch & Struct linked into my model. I uploaded my model, and I also uploaded the Arch & Struct models too (my original intent was to be able to link them together, but I found out that's not possible unless we are using Glue). However, this happens whether I try and view my model, the arch model, or the struct model for this project.
They were all drawn in Revit.
I will send you a PM shortly. Thank you.
Hey @ben,
Just wanted to follow up with regards to our communication. It seems like after you changed to a different browser, you were able to view your models. It seems like the original issue was related to browser compatibility with Internet Explorer.
For browser compatibility, please take a look at the A360 browser requirements. Internet Explorer 11 is listed, however there are known limitations that our team is aware of. Internet Explorer 8, 9, and 10 don't support WebGL, so they can't show either 2D or 3D design files. They can only show nondesign files.
If you consider your forum post resolved, please choose Accept as Solution so that other community members can find the answer as well.
Thank you and have a great day,
Patrick B.
It's weird because I'm using Internet Explorer 11 and it wouldn't work, but it did work with Firefox
