I'm trying to retrieve my older files from A360 before it's End of Life.
I see errors when I try to view as well as download from A360.
View error message reads:
Sorry. We have encountered some issues when preparing file for viewing. Please contact support for assistance.
Details
Tr worker fail to download.
When files are bulk downloaded they are zipped but most are 1 KB in size and have a ".err" extension added and can't be opened in Autocad or other dwg editors.
The .err files contain XML reading:
<?xml version="1.0" encoding="UTF-8"?>
<Error>
<Code>NoSuchKey</Code>
<Message>The specified key does not exist.</Message>
<Key>SHDFRYYPB8XC/my/root/741ebc28880e4f6a88a18ccc2873b2a4-8724801e87c4459c97597d46c5486ef2</Key>
<RequestId>864313BFC294E908</RequestId>
<HostId>FNEj2MkkixKnlsF6PDnWz57DC2XH4Uf8BRoZaVZIL4INfnx5jPzWxJeAO2S3ISMFrTPCHakcKwQ=</HostId>
</Error>
If I had to guess, the file is missing or the pointer reference to it is bad. Is there anything I can do to correct or retrieve the files?
Thanks, Eric
I'm having exactly the same problem: The files on the a360 cloud service appear to be fine (the size is correct, as well as the modification date). However, an error: "Tr worker fail to download" always appears, and, if I download all of my files as a zip, some files are just 1kb and have a .dwg.err when unzipped (they are described as an error log file). This same error appears whenever I try to visualize some of the files which appear to be badly downloaded (some of my files are just fine and can be visualized and donwloaded without any kind of problem, but the good files are in a ratio of just 4:33 in comparison with the failed ones. Hope we can be helped by the community. Those files are very important to me, and I hope this is all a server issue or a similar error.
Alex
Hello Eric,
Thanks so much for reporting this issue!
I sincerely apologize for the issue you are encountering. We will start the investigation right away.
Please note that you will have until the end of September 2020 to download your files.
I will keep you posted on the progress.
Molly
Hello Alex,
Thanks so much for reporting the issue in this thread!
I apologize for the inconvenience. We will start the investigation right away.
I will keep you and Eric posted on the investigation progress.
Molly
Hello Alex,
Thanks for being patient!
Could you please private message me the email address that's linked to your Autodesk Account?
This will help us investigate the root cause.
Molly
Hello Eric,
Thanks for being patient while we investigate.
Molly
I replied with my email address, it's been a few months with another month or so before we can't download, have there been any updates?
