A360 Drive Forum
Welcome to Autodesk’s A360 Drive Forums. Share your knowledge, ask questions, and explore popular A360 Drive topics.
Can't access A360 Drive
19 REPLIES 19
Message 1 of 20
Vitornis
1922 Views, 19 Replies
Every time i press the sign in button it just redirects back to this page https://a360.autodesk.com/drive/
19 REPLIES 19
Message 2 of 20
Hi Dennis,
Thanks for letting us know and I was able to reproduce it. I did ask the team if they know what is going on here. Once I hear back, I will post a message.
Thanks again for letting us know.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Autodesk Beta Programs!
Message 3 of 20
Please give this a try now, it is back up and running.
Sorry for the delay, and hope this helps.
Bud Schroeder
Autodesk Inc.
Tags (2)
Message 4 of 20
Currently can't logon again. It just loops back to the sign on screen.
Message 5 of 20
Thanks Tim for posting to the thread. We pushed out some updates yesterday and one of the updates caused this issue. We fixed this, but if you were signed in during this time frame you will see the looping issue.
If you clear your browser cache and history, then close all instances of the browser windows. Re launch and you should be able to sing in then.
Give this a try and please let us know how this goes. And thanks again for posting to the forums.
Bud Schroeder
Autodesk Inc.
Message 6 of 20
Thanks for the tip.
Did all of that and tried two different browsers on the same machine.
Here is the web address I see when asked to log in : https://a360.autodesk.com/drive/
During the login procedure the address changes to : https://a360.autodesk.com/drive/app/root
Then loops back to sign in.
Message 7 of 20
tewindle
in reply to: tewindle
had another user log on from a different machine, and they have the same issue. However, if I login from that machine, it works ok. We cleared browser cache for the past week....interesting issues that seem hard to duplicate.
Message 8 of 20
Hi Tim,
Can you tell me what browser you are using? Also if Chrome, can you try incognito mode and see if that works?
Thanks and please let us know.
Bud Schroeder
Autodesk Inc.
Message 9 of 20
we are using Chrome, but tried on Edge and had the same issue.
Message 10 of 20
Hi Tim,
Thanks for the update.  Were you able to try Chrome in INCOGNITO mode?
Thanks and let me know how this goes.
Bud Schroeder
Autodesk Inc.
Message 11 of 20
Hi Tim,
I had one other person that was having the same type of issue and this helped resolve the problem.   Click on chrome://settings/clearBrowserData
And select all option there and the past week:
Thanks and please let us know how this goes.
Bud Schroeder
Autodesk Inc.
Message 12 of 20
That is the same way we clear browser cache.
Interesting thing logging in Incognito goes to the older login window in which you input username and password on the same screen and it logs into A360. I can then click A360 drive and get to our share folders. So this workaround seems to work, but simply clearing the past week browser cache didn't seem to fix anything.
Message 13 of 20
Hi Tim,
Thanks for the update. So far this has worked for every one, so I'm suprised it's not working. We are trying a different fix that should be posted soon that would not require clearing the cache, lets see if that works. I'll post back when it's live.
Thanks again for letting us know what you are seeing. That is very strange.
Bud Schroeder
Autodesk Inc.
Message 14 of 20
Hi Tim,
Can you give it a try now and see if you can access with out being in INCOGNITO mode.
Thanks and let us know how this goes.
Bud Schroeder
Autodesk Inc.
Message 15 of 20
I was able to log in to A360, which gives me the username and password on the same screen. I can then click A360 drive from the pulldown and access my shares. Not sure if this is the intended path, but it works.
Message 16 of 20
Thanks for the update Tim and let us know if you have any other issues with this.
Bud Schroeder
Autodesk Inc.
Message 17 of 20
in reply to: Vitornis
Hi, I'm having same problem too and could you suggest how to do procedure with MAC. Thanks
Message 18 of 20
Bud_Schroeder_ADESK
Thanks for posting your question to the forum and welcome. Can you try clearing the cache and cookies to see if you can sign in. If that works also do a Control F5 to force a refresh of the page and see if that helps.
Thanks and please let us know how it goes.
Bud Schroeder
Autodesk Inc.
Message 19 of 20
in reply to: Bud_Schroeder_ADESK
Hi seems solved. thanks
Message 20 of 20
Bud_Schroeder_ADESK
Thanks for letting us know and have a great day.
Bud Schroeder
Autodesk Inc.
