It appears there is an extra “\” …\AutoCAD 2013 – English\R19.0\enu\\Support\.
I don’t know if this is causing the error or not.
I tried these articles but everything checked out.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9579121&linkID=9240617 and http://support.microsoft.com/kb/886549
Not sure what to do next.
Will you post your system specs and what OS you are using? That might help some of the more IT minded folks in here to figure out something for you.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Have you tried installing from a CD DVD, Thumbrdrive, or by copying the installation folders to your Hard Drive?
@David_Knight wrote:Have you tried installing from a
CDDVD, Thumbrdrive, or by copying the installation folders to your Hard Drive?
From the thumbdrive.
I presume you get the same error then?
I'm not sure.
Those are the things I would have tried.
If there is in fact an error in your user profile (as the links you listed suggest) I would try either
and trying the installation again.
I also presumed you had admin privileges when you attempted to install. If you do not, that is likely an issue of some sort as well.
@David_Knight wrote:I presume you get the same error then?
I'm not sure.
- creating a new user profile (or)
- logging in as the admin profile
There is no problem with the user profile. That checked out. I do have admin rights on this PC.
The only thing I have't tried is copying the files from the thumbdrive to the hard drive. Why would that cause an issue?
Because part of the installation procedure installs Framework (plus hotfix). Framework is quite sensitive to non-trusted drives, so if your security settings are default (or stronger) a network-drive (or external drive) might be blocked for some update process. So it really makes sense to copy the installation files to a local folder (on C:) and start then the installation.
And remember, the message tells you that you have a network-problem during installation.
Why are you that sure, at least you have a problem with installation and we don't know where. So it's a tip to run that with another profile just as an option.
Great, and you have started the SETUP.EXE with right-click and option "start as administrator" or you have disable UAC?
Just to have admin-permissions does not mean you start the programs with admin-permissions, that changed since Vista.
You also can start with first installing the DirectX-components from the installation media, then the Framework (+hotfix) and when this is finished, then try to start the AutoCAD-installation again.
If it again fails, please upload the log-file that was created during the AutoCAD-installation.
- alfred -
- alfred -
It failed again. Where do I find this log file?
Found it.
2013/4/2:12:05:02 msmall ESI069 === Setup started on ESI069 by msmall === 2013/4/2:12:05:02 msmall ESI069 Launch 2013/4/2:12:05:08 msmall ESI069 === Setup ended === 2013/4/2:12:05:16 msmall ESI069 === Setup started on ESI069 by msmall === 2013/4/2:12:05:16 msmall ESI069 Launch 2013/4/2:12:05:19 msmall ESI069 === Setup ended === 2013/4/2:12:05:17 msmall ESI069 === Setup started on ESI069 by msmall === 2013/4/2:12:05:17 msmall ESI069 Launch 2013/4/2:12:05:19 msmall ESI069 PageOpen LaunchDialog 2013/4/2:12:05:20 msmall ESI069 PageOpen LicenseDialog 2013/4/2:12:05:23 msmall ESI069 PageOpen ProductInfoDialog 2013/4/2:12:06:14 msmall ESI069 PageOpen ProductSelectionDialog2 2013/4/2:12:06:29 msmall ESI069 PageOpen FullProgressDialog 2013/4/2:12:06:29 msmall ESI069 Installing Autodesk® Design Review 2013: TRANSFORMS="C:\Users\msmall\AppData\Local\Temp\_AI3084.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/4/2:12:06:42 msmall ESI069 Install Autodesk® Design Review 2013 Succeeded 2013/4/2:12:06:42 msmall ESI069 Installing DirectX Runtime: C:\AutoCAD Design Suite\3rdParty\DirectX\DXSETUP.exe /silent 2013/4/2:12:08:05 msmall ESI069 Install DirectX Runtime Succeeded 2013/4/2:12:08:06 msmall ESI069 Installing Autodesk® Material Library 2013 - Medium Resolution Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/4/2:12:08:29 msmall ESI069 Install Autodesk® Material Library 2013 - Medium Resolution Image Library Succeeded 2013/4/2:12:08:29 msmall ESI069 Installing Autodesk DirectConnect 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/4/2:12:09:23 msmall ESI069 Install Autodesk DirectConnect 2013 Succeeded 2013/4/2:12:09:24 msmall ESI069 Installing Autodesk® Showcase® 2013: TRANSFORMS="C:\Users\msmall\AppData\Local\Temp\_AI3084.tmp\x64\Showcase\AutodeskShowcase7.0-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" INSTALLDIR="C:\Program Files\Autodesk\Showcase 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/4/2:12:14:49 msmall ESI069 Install Autodesk® Showcase® 2013 Succeeded 2013/4/2:12:14:49 msmall ESI069 Installing Autodesk® SketchBook® Designer 2013: TRANSFORMS="C:\Users\msmall\AppData\Local\Temp\_AI3084.tmp\x64\SBD\SBD-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" INSTALLDIR="C:\Program Files\Autodesk\SketchBookDesigner2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/4/2:12:15:55 msmall ESI069 Install Autodesk® SketchBook® Designer 2013 Succeeded 2013/4/2:12:15:55 msmall ESI069 Installing Autodesk® SketchBook® Designer for AutoCAD® 2013: TRANSFORMS="C:\Users\msmall\AppData\Local\Temp\_AI3084.tmp\x64\SBDACAD\SBDACAD-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" INSTALLDIR="C:\Program Files\Autodesk\ApplicationPlugins\SBD.bundle\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/4/2:12:16:19 msmall ESI069 Install Autodesk® SketchBook® Designer for AutoCAD® 2013 Succeeded 2013/4/2:12:16:20 msmall ESI069 Installing Autodesk® Mudbox® 2013: TRANSFORMS="C:\Users\msmall\AppData\Local\Temp\_AI3084.tmp\x64\Mudbox\Mudbox2013.0-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" INSTALLDIR="C:\Program Files\Autodesk\Mudbox 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/4/2:12:17:31 msmall ESI069 Install Autodesk® Mudbox® 2013 Succeeded 2013/4/2:12:17:31 msmall ESI069 Installing Autodesk® Raster Design 2013: TRANSFORMS="C:\Users\msmall\AppData\Local\Temp\_AI3084.tmp\x64\Raster\Raster-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\AutoCAD Design Suite\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Raster Design 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/4/2:12:18:46 msmall ESI069 Install Autodesk® Raster Design 2013 Failed Installation aborted, Result=1603 2013/4/2:12:19:10 msmall ESI069 Rollback Autodesk® Mudbox® 2013 Succeeded 2013/4/2:12:19:25 msmall ESI069 Rollback Autodesk® SketchBook® Designer for AutoCAD® 2013 Succeeded 2013/4/2:12:20:16 msmall ESI069 Rollback Autodesk® SketchBook® Designer 2013 Succeeded 2013/4/2:12:21:53 msmall ESI069 Rollback Autodesk® Showcase® 2013 Succeeded 2013/4/2:12:22:13 msmall ESI069 Rollback Autodesk DirectConnect 2013 Succeeded 2013/4/2:12:22:18 msmall ESI069 Rollback Autodesk® Material Library 2013 - Medium Resolution Image Library Succeeded 2013/4/2:12:22:18 msmall ESI069 Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2013/4/2:12:22:24 msmall ESI069 Rollback Autodesk® Design Review 2013 Succeeded 2013/4/2:12:22:24 msmall ESI069 PageOpen InstallCompleteDialog 2013/4/2:12:49:20 msmall ESI069 === Setup ended === 2013/4/2:12:51:15 msmall ESI069 === Setup started on ESI069 by msmall === 2013/4/2:12:51:15 msmall ESI069 Launch 2013/4/2:12:51:18 msmall ESI069 === Setup ended ===
first failure I see is Raster-Design. Try to disable "Raster Design" from the list of products to be installed and try it again.
- alfred -
Would this headache go away if I were to install it with a local profile on this machine?
With a local profile everything should install fine.
Check out the following section from http://usa.autodesk.com/getdoc/id=TS1055299
Folder redirection
There are several ways to redirect certain folders from within the user profile, including (but not limited to) the Start Menu, My Documents or Temp folders. This customization can be done directly on the computer or with network management software, such as Microsoft Active Directory and Group Policies. These types of customizations can cause failures in the AutoCAD secondary installer which might result in error messages, such as Error 1606: Unable to access network location. To correct this issue, you should remove folder redirection from the user, reboot the machine, and then try to run AutoCAD again.
Danny
@DannyHubbard wrote:With a local profile everything should install fine.
Folder redirection
Danny
Thanks a lot Danny! I'll see if I can't have that folder redirection disabled temporarily, or just use a local profile to install with.
Same problem – I have tried everything I found on internet, but no change. Then I’ve decide to create a new user account, and Acad 2014 installation had no problems. After that I simply switch to the original user account and Acad 2014 installation was OK on this user account as well. That’s how it works for me (Win 7x64 – Autocad 2014x64):
It works for me – I hope it works for you either
I appreciate your helpful replies. That said, I would like to take a moment to rant regarding AutoDesk's need to make this sort of thing so difficult and internally complex. Why do we need a 12-step process to load a viewer?! Perhaps there could be a "light" version for those of us relatively normal users who do not care to use all the accessory applicatiions AutoDesks thinks we need or would like us to use. My goodness! Give me a one-file download that does not rely on three other products that also have to be installed. Just let me load and look at a DWG.
-Cheers-
@Anonymous wrote:Hi,
- Go to user accounts and create a new account as Administrator
- Log on with new account
- After logon go to Switch user and Go back to the original account
- That’s it – now you can install Acad 2014 with original account
This is what I'm trying next. Our IT guys wanted to try something else, but I still got the same error.
Well, ended up disabling roaming profiles and folder redirection. So now I have a local profile. This appears to have solved the issue. Everything seems to have installed properly and is working correctly. It even corrected the problem I was having with properties not displaying for the selected object.
IMO it's poor programming on AutoDesk's part to not be able to account for that. It seems like it's a pretty common IT practice.
Thank you to those who helped out!
