I'm trying to reinstall Autocad 2007 on my computer at work after the hard drive was reformatted to remove a virus. It installs okay but when I enter the Activation code it tells me ther is a problem with the code. I called Autodesk and got a new number and even went through the acitvation on the internet and got another number but get the same message with each. I've double checked my typing to make sure that I entered the number as listed, it won't let me paste it in. Can anyone help me?
Solved by jessica.t. Go to Solution.
Uninstalled the program and reinstalled then went through registration again and it took this time.
Thanks for looking.
Ron
Hi BasurajBhowmik,
Could you please send me your serial number through private message? Click on my celine.manca profile and then "send this user a private message".
Thanks!
I'm having troubles with licence and installing AutoCad 2007 on one of employees computer's.
I have serial number, request code, but no activation code. I tried to transfer license, but when tried importing it, it said it's not a valid file.
Can you please send me activation code?
Thank you,
Best regards
Hi UrosO and welcome to the forums!
Can you send me the serial number, request code and company name via private message (envelope next to your name) ?
I'll check the license and provide you an activation code.
Thanks!
Hi again UrosO,
Thank you for the addional information regarding the activation of your license.
For futur transfer of license on your AutoCAD 2007, I recommend you this solution about the Portable License Utility.
Céline
And thanks again for your quick assistance and provided solution which I will try if problem reoccurs.
best regards,
Uros
Please Private Message me (click on my joane.bonghanoy profile name and then “Send this user a private message”) your Serial Number and Request Code.
Hello, My name is Jake Padgett. I am repairing a computer for someone who had win xp w/ autocad 2007 on it, the system crashed and i installed win 7 and reinstalled autocad 2007 have orignial serial - License ID - and (acd2007enuregemail) file. when tried to activate didnt work.
Thanks for any help you can provide
i need activation code for my autocad 2007 , i have the serial number and request code but i don't have the activation code .please i need it , my serial number is xxx-xxxxxxxxx. THANKS
Hi jeffrey0147,
I have edited your message to remove sensitive information.
The serial number you posted here is not a valid serial number issued by Autodesk. May I ask where this serial number was obtained?
Thank you
Hi!
I also have troubles with licensing the AutoCad 2007 on one of the user's computer.
I upgraded computer from XP to Win 7, and before that I exported the licesce to the same computer with activation code. Now the activation code is different, and I can't import license.
I have request code and serial, can somebody please generate activation code for me?
Thank you,
Regards
Hi UrosO,
Please, send me the request code and serial number via Private Message for the activation (click on my camilo.lemos profile name and then on Send This User a Private Message).
Note that AutoCAD 2007 is not supported on Windows 7 so you will have to use the XP compatibility mode.
Best regards,
Hi!
Thank you for your help, but I already solved this problem with your staff through private messages.
And we don't have any problems with Autocad 2007 on Win 7, we just need to install the service pack 2.
I'm trying to reinstall AutocadLT 2012 on my computer after the hard drive was reformatted from Windows XP to Windows. How should I proceed ?
Not sure my previous message is posted at the right place...
Please note to clarify my request for help:
- My computer was upgraded from Windows XP to Windows 7;
- I try now to reinstall AutocadLT 2012 using my Autodesk CD disk;
- When the installation is aborted I receive the following message : 2013/7/2:18:03:33 pdeke DEADK102500Y1 Installing .NET Framework Runtime 4.0: D:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/7/2:18:04:12 pdeke DEADK102500Y1 Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603.
