ObjectARX
custom paper size
3 REPLIES 3
820 Views, 3 Replies
custom paper size
hello together,
the topic „custom paper size“ has already mentioned in several threats,
but unfortunetely there are no answers which give me help.
is it possible to add a „custom papersize“?
Would this be a solution maybe?
- to edit the pc3 file – are there any interfaces or is a word proseccing of the file possible?
- or does the „AcPlPlotInfoValidator“ can be used where is also a function „isCustomPossible“
  or "AcPlPlotConfig::makeCustomMediaFromSizeDesc"?
- there is also an assistend  where you can add a plotter (Pc3 file)
   which is in the same folder like the pc3 files – does this maybe work out?
i am looking forward to get an official response to this problem and also every suggestion which can be helpful.
Thank you all...
3 REPLIES 3
Balaji_Ram
Sorry, there is no API to create a custom paper size.
Also the PC3 file is a compressed file similar to a .CUIX and cannot be parsed as an XML.
A way to use custom paper size is to use the "Plotter Configuration Editor" (launched by double clicking a pc3 file) to create a new pc3 file with the custom paper sizes.
This pc3 can then be deployed in the plotter folder.
Balaji
Developer Technical Services
Autodesk Developer Network
xiaomenggg97
in reply to: Balaji_Ram
So is there Such an API now?
No.
Facebook | Twitter | LinkedIn
Expert Elite Member
Forma Design Contest
