3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
White outline on scene objects
3 REPLIES 3
942 Views, 3 Replies
I'm getting this white outline around objects in this architectural scene, I'm wondering what is usually the cause of this. I assume it's to do with the background image set up in the environment options. The problem is it isn't my scene so I'm not too familiar with the environment effects the creators were using.
Any suggestions? I'd rather not have to make a mesh sky dome, but that may be the only fix possibly. Thanks for any ideas
Lloyd
3 REPLIES 3
dominique.bouthillette
Hi @Anonymous,
From the screenshot you provided it looks like there are Opacity maps being used in the scene for the trees. Sometimes if these Opacity maps aren't very 'clean' or do not extend all the way to the the edges of the image for the Diffuse map being used they can sometimes show white edges around the Plane or Model. Additionally, the white around the building may be from anti-aliasing when rendering.
Could you perhaps share the scene file and maps and I can have a closer look? =]
Thanks so much!
Please Accept as Solution if a reply has helped resolved the issue or answered your question, to help others in the community.
Kindest regards,
Dominique Bouthillette
Principal Specialist, Industry Support & Escalation
Entertainment & Media Solutions
Hi @Anonymous,
Just wanted to follow-up here to see if you were able to resolve the issue. Please let me know if I can help in anyway. =]
Kindest regards,
I'm having this issue as well. Turning off opacity maps doesn't get rid of it.
From the screenshot, you could see that the white outline applies to the buildings as well.
Edit: I have found the white outline to be in the lighting (dome) pass. Making it invisible (Options > Invisible) managed to solve my issue.
