I want to add hdri in my render but I can not find Vraybitmap in Material/Map browser.
Solved by RobH2. Go to Solution.
First, is the 'Rederer' set to VRay. Next, in 'Slate' if you right click in the window you should see 'Maps/V-Ray' and in 'V-Ray' you should see 'VRayBitmap' as the first map. No?
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------One of the best things you can do as a new user is to just click on every button and see what pops up. You'll find a lot of things you weren't looking for and you'll eventually find what you "are" looking for. It will help you begin to know the interface and it's not a waste of time.
Here's where it is, see attachment.
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------My pleasure... 🙂
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------You didn't mention which version of Max you are using but I'd try two things. Uninstall VRay and then do an ENU reset. Then reinstall VRay.
Rob Holmes
I wish I had more to help you with. I just uninstalled VRay from Max 2021 and installed the latest version. And, VRay Bitmap is definitely there as it should be.
I think you might want to head over the Chaos Group's VRay Forum and post there. I think this may be a VRay issue and not a Max issue.
I wish I had more help but I don't know what else to try if you've done all the things above.
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------Can't find what you're looking for? Ask the community or share your knowledge.
