I have installed the Vray plugin for 3d max 2018 and I have the plugin folder with a ton of files in it. In the plugin folder but the renderer is not showing up in 3d max under render setup.
What to do?
Solved by rendermaster. Go to Solution.
have you tried the old school way of using the 3ds max plugin manager? https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMa...
no commercial release yet of vray for 3ds max 2018. their latest is only for 3ds max 2017.
check here: https://docs.chaosgroup.com/display/VRAY3MAX/3.50.04
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Hello @Anonymous,
As mentioned by @rendermaster, the 2018 version of Vray isn't released yet. The 2017 version won't work in 2018. For problems with various plugins, it's always best to post on the forums of the plugin makers rather than here as there's not much I can do about Vray errors or problems. Thanks!
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
