Shadow Color Reflected from Material
Dear Community
I am quite new to 3DS software but I found it amazing because we can render a realistic image
with high level of detail
My problem is, when I did a rendering, the color of shadow under the object is reflected from the color of material. In this example, Im using a standard material (green) and the shadow color around the material is faded green. I want the entire shadow color be grey.
Render of a Teapot
Lighting Setting
Material Setting
Please help me
Thanks in advance :))
irishman_team_kilber
Go to the Shadow parameters and click on the color swatch box and then you can change the shadows to gray. you may need to change the shadow Density, the Density value increases the density (darkness) of shadows. Decreasing Density makes shadows less dense
Did you manage to change the parameters colour to gray?
