I know that Thinkbox Deadline isnt a Autodesk product, but asking here if someone had the same issue
Im working in 3dsMax 2024 with OCIO activated, ACEScg, when I render the sequences in my PC the colors are Ok, but I do the Network rendering using Deadline, the colors are different. I noticed that in the Render window is a message: "Color mgmt OFF"
even when I assign the PC where the project was made to be the only machine in the TASK, it turns off the OCIO config, and the colors are wrong. Someone had this issue before with the plugin?
I haven't used Thinkbox Deadline in a few years but when I did I seem to recall they had a pretty robust forum. Have you posted there? You might find more help on that forum.
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------Can't find what you're looking for? Ask the community or share your knowledge.
