3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
texture isn't completely wrapping around the object
4 REPLIES 4
986 Views, 4 Replies
i'm setting up reference images for making a biped model and the texture didn't show up until i set the size of the bitmap in the texture to the dimensions of the plane. the bitmap i wanted to use was very small and even now is not completely wrapping around the sphere in the compact material editor. how do i set it to wrap around the material completely?
4 REPLIES 4
miledrizk
Uncheck the option "Use Real-World Scale", and set the size in both Width and Height to 1
Also in the Plane object, make sure this option is Uncheck too, same thing in case you applied
A UVW Map modifier.
miledrizk@gmail.com
3DS Max 2021, V-Ray 5.2
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
My YouTube Channel http//www.youtube.com/c/MiledRizk
in reply to: miledrizk
Where is the scale?
miledrizk
In the Material Editor you'll find it like in the picture below:
For the Plane object:
And finally, for the UVW Map modifier:
miledrizk@gmail.com
thanks. i meant the scale slider but i realised just now that i converted the plane to a editable poly earlier so i just need to remake that. thank you very much.
Technology Administrators
