3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Scaling material texture to fit object
2 REPLIES 2
22944 Views, 2 Replies
I'm trying to use a material from the library in my rendering, but I'm having a problem with the texture scaling/tiling.
Essentially, if I just unwrap the UVs of the model, and then pack them in the standard square size, all I get is a solid color (as if the color comes from a single pixel in the image instead of the whole texture).
So I just enlarged the UV, to a ridiculous amount I think, and it got better:
But as you can see the grain it's still really big. In the settings of the material itself, there is no "tiling" option anywhere. What can I do to get a better result? Is the only option really to just enlarge the UV until I get a scale I like?
2 REPLIES 2
rendermaster
try this....Real World mapping  and or Apply Map Scaler or apply UVW Map
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
in reply to: rendermaster
using UVmap modifier helped me and let me change the texture projection. Thanks!
Technology Administrators
