3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Rotate Env Map
11 REPLIES 11
Message 1 of 12
4927 Views, 11 Replies
Rotate Env Map
Is there a way to rotate a spherical environment map? I'm using an HDR image to light a scene but I want to change the angle of the light.
The bitmap transform controls don't seem to do anything.
11 REPLIES 11
Message 2 of 12
If you instance copy your hdri from you environment panel to the material editor you can rotate it there
Message 3 of 12
It dosn't work for a spherical env map. I can change the rotation in the mat editor but the lighting dosn't change.
Message 4 of 12
Use the U Offset.
Message 5 of 12
syndicate5
That still doesnt work. Ive NEVER been able to get it to work from within Max without using a 3rd party workaround. Next suggestion? Also suggest something that youve actually seen work.
https://www.instagram.com/bumblebee_3d/
Message 6 of 12
RobH2
in reply to: syndicate5
@syndicate5 , actually, the suggestion @Anonymous made works nicely. Review your technique and try again. Make sure your settings are correct but it works flawlessly in Max 2018, 2019, 2020 and Max 2021. I tested them all just to make sure.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Message 7 of 12
Richard.Vivanco
Are you sure you dragged the map as instance ?
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
Message 8 of 12
Also, disable real-world map size in preferences before dragging the map into slate.
Message 9 of 12
FNK
in reply to: cliftonSantiago
Hi, I've tried changing the U offset value.
It works, but you have to use values less than ±1.
If you use integer values it seem that the map makes a complete rotation.
Francesco MUZI
Digital Content Creation & Virtual Reality
Innovative Technologies Dept
____________________________________
ISSELNORD srl
Via Trieste 4, loc. Ceparana
19020 Follo, La Spezia (Italy)
Tel. +39 0187 941414
Fax +39 0187 941420
www.isselnord.it
Message 10 of 12
RobH2
in reply to: FNK
Even if the values are locked to 1.0, can you still put in .05 for a 5% rotation for .5 for a 50% or 180 degrees. Does that work at least to keep you going?
Rob Holmes
Message 11 of 12
Can verify in Max 2022. Instance it to material slate,
Switch to SLATE (didn't have an effect in compact for me)
Then instance the scene sample slot BACK to the env tab
Then ONLY the mapping Rotations / flip horizontal & Output tabs had an effect.
Message 12 of 12
in reply to: FNK
Merci beaucoup !
