3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Retopology Bug?
2 REPLIES 2
Turok1
406 Views, 2 Replies
Retopology Bug?
Turok1
Greetings.  I don't know if this is a bug or if I'm doing something wrong.
I created a rectangular box and added a Edit Poly modifier and UVW map and textured it. I also used soft selection and edited the geometry.
When I used the Retopology modifier, the texture that I had previously applied turned into an smooth ebony black color over the model. When turning off the Retopology modifier, I can see my texture, but turns ebony black when going back to the top of the stack.
I added another edit poly on top and reapplied the material and it remained a black color.  I even added another UVW on top of that and still no joy.  I then collapsed the stack and the model still cannot be textured.
Retopology Bug?
2 REPLIES 2
wernienst
in reply to: Turok1
wernienst
In the Auto Edge rollout, check UV Channel (it's off by default) and set it to the appropiate texture channel. Then repeat Retopology.
Turok1
in reply to: Turok1
Turok1
Awesome!  Thank you, that worked like a charm. 👍
