Render Setup won't open
Hi. I've just installed 3ds MAX 2017 on my laptop (which runs Windows 10) and every time I click on the render setup button, or hit F10 on my keyboard, the render setup window doesn't appear. I've been waiting 5 minutes for the thing to load and it hasn't displayed the window. How do I fix it?
-Kyle
Replies (8)
just out of curiosity, have you ever run an another monitor alongside your laptop, or something similar?
Yes. I have a dual monitor set up. Is that what’s the problem?
Sent from Mail for Windows 10
I have had a problem very similar to this when I switched over the inputs on my monitors. The render setup window stays where it is and the monitor moves (virtually). if that doesn't make sense, don't worry.
try running just one screen and see if it reappears. Let me know how you get on..
I tried opening my project on just my laptop and no other monitor attached and it’s still not loading. The button is showing that it is clicked, but nothing is appearing. What do I do now?
I am experiencing the same issue and cannot find the render setup window, either.
BenBisares
Autodesk Support
Autodesk Support
I see this happening often with multiple monitor setups. For example if you place the Render Setup window in the 2nd monitor, quit Max, disable the 2nd monitor or reposition it, then open 3ds Max, the Render Setup window will still be positioned in the old space. You can reposition using the following steps:
  • Open the Render Setup window. Although it's difficult to see you need to ensure that the focused window is the Render Setup window. So after you click on the button or hit the [F10] shortcut key do not click on any other window
  • Press [ALT] + [SPACEBAR] which will open a Windows menu, choose "Move"
  • Press any of the arrow keys on the keyboard
  • Without clicking on any mouse button, move the cursor. You should now see the Render Setup window stuck to the cursor
  • Position where you want and then left click to drop the window
You can take a look at the video I made here
http://autode.sk/2k2poEd
Ben Bisares
You just saved me from mental breakdown.
11925281
Community Visitor
Community Visitor
I registered here just to tell you thank you! Your answer really saved me!
