3ds max crashes when rendeing after aplying vraymtlwrapper to a vray plane
Over the years I've had a few of these oddities come up. You didn't mention what versions of Max and VRay you are using (which is always suggested) but it's likely not a bug but a misconfiguration. I've almost always solved them by doing and ENU reset and reinstalling VRay. Reinstalling VRay is pretty fast and easy.
For the ENU reset, do some reading beforehand. You can save a lot of time reconfiguring your custom workspace setup if you do it properly. But, it's a skill that you should get familiar with because ENU resets will save your life frequently. I have a backup routine that saves my current ENU every night. That way if one causes problems, I can revert to a known good one and keep rolling. I also have a pretty good post on doing an ENU reset and a list of the steps I take. If you search for that you can find it.
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------Can't find what you're looking for? Ask the community or share your knowledge.
