3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Realistic Material with Maps
5 REPLIES 5
1354 Views, 5 Replies
I was Practicing on my Drop Ship and i have encountered a problem when ever i use realistic material my NURBS objects losses it's shape.
5 REPLIES 5
JamesClarke3D
1 - I noticed you're in shaded mode not realistic
2 - Do your materials/maps have transparency somehow? (Perhaps disable transparency in Viewport Shading menu to test if they become visible...)
| LinkedIn | @SnipeyX |
in reply to: JamesClarke3D
I too Have noticed that but it's both showig both same in written wheter i choose maps with realistic material or simply with shaded.and let me check the transparency and i will get back to you thanks.
This with TRansperancy Disabled.it is still isn't showing.
JamesClarke3D
Yeah my bad, I didn't look at the original images close enough and thought something was just disappearing, but I see now that it appears to actually be changing shape for some reason. No idea there really, a guess would be possibly something to do with the tesselation settings changing when in realistic display mode perhaps? For troubleshooting to determine what's going on: Maybe you could isolate the object that changes and see what's different about it? What if you put a standard material on everything with no maps? What shape does it look like when rendered?
Yeah.Figured it out anyway used normal modifier and every thing worked out.
