3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Pre-Render Test
2 REPLIES 2
drford-323
313 Views, 2 Replies
Pre-Render Test
drford-323
I'm using 3ds Max 2017 and I was wondering if anyone knows if there's a script or a feature that will run a pre-render check to see if there are problems with the scene (missing textures or Missing UV's) in a dialog that will stay up so we can identify those problems? As it is the dialog that comes up before rendering must be closed before you can start finding the problems. In large scenes this can be problematic.
Pre-Render Test
2 REPLIES 2
CiroCardoso3v
in reply to: drford-323
CiroCardoso3v
SINI has the Forensic, which I believe it is free.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Ciro Cardoso
CAMedeck
CAMedeck
For finding missing texture maps, I like using a script from Colin Senner, Relink Bitmaps.  It will give you a list of any missing maps and help you to relink to their location, or identify what material they're used in.
Chris Medeck
Chris Medeck
