3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
polygons extrude
2 REPLIES 2
abdallah-A-Z
355 Views, 2 Replies
polygons extrude
abdallah-A-Z
when I use extrude to polygons, the materials appear distorted around extruded part
The same problem occurs when using Bridge, Bevel, and Extrude.
Is there a solution to this problem ?.
polygons extrude
2 REPLIES 2
oliver
in reply to: abdallah-A-Z
oliver
Assign new UVs with UVW-Map-modifier or unwrap with UnwrapUVW-modifier.
abdallah-A-Z
in reply to: oliver
abdallah-A-Z
thank you very much
thank you very much
