It seems if I used "advanced" with phsycial material and put reflection at 0, roughness at 1...and roughness at 1 for Basic, I still get a reflection with scanline. Or at least a pretty visibly reflection of the light source...like a shine from a nearby light.
Is there any way to get rid of this or would you suggest just switching to a standard material for this.
(For glass and metal, physical material looks great with scanline)
Solved by rendermaster. Go to Solution.
try.. turning the reflection color will totally eliminate reflection on the object
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
i mean, try.. turning the reflection color to black will totally eliminate reflection on the object
Do you know if there is a way to keep the reflection but blur it the way roughness does so well with ART and Arnold?
So the reflection is there, but not sharp.
