3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Physical Material with Scanline
5 REPLIES 5
2058 Views, 5 Replies
It seems if I used "advanced" with phsycial material and put reflection at 0, roughness at 1...and roughness at 1 for Basic, I still get a reflection with scanline.  Or at least a pretty visibly reflection of the light source...like a shine from a nearby light.
Is there any way to get rid of this or would you suggest just switching to a standard material for this.
(For glass and metal, physical material looks great with scanline)
5 REPLIES 5
rendermaster
try.. turning the reflection color will totally eliminate reflection on the object
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
rendermaster
i mean, try.. turning the reflection color to black will totally eliminate reflection on the object
Thank you. Will try this.
in reply to: rendermaster
Yes, thank you.
Do you know if there is a way to keep the reflection but blur it the way roughness does so well with ART and Arnold?
So the reflection is there, but not sharp.
