3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
OSL get_texture_info(): unspecified OIIO error
3 REPLIES 3
luka6A5H6
270 Views, 3 Replies
I'm trying to render using arnold renderer in 3ds max.
I'm using udim, and I think this is probably the cause.
I keep getting an error, but I haven't found a solution yet.
I need help.
3 REPLIES 3
Stephen.Blair
in reply to: luka6A5H6
OSL Bitmap Lookup with udim textures seems to work fine. Did you try using a regular Arnold Image map, just to confirm that the texture files are good?
// Stephen Blair
// Arnold Renderer Support
luka6A5H6
in reply to: Stephen.Blair
If this doesn't work, what's the problem?
And how should I solve it?
Stephen.Blair
What does "this" refer to? Using an Image map to load the texture?
If an Image map cannot load the texture, then try with a different png file. Try to isolate the problem. Is it just that one png file? Where'd it come from? Create a simple test scene with a simple material. Try some different texture files. Can you load a specific udim texture (eg don't use the udim token, load a specific file like test_1011.png). Is it a permissions problem? Can MAXtoA read files from that folder?
// Stephen Blair
