3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
nothing appears in render
16 REPLIES 16
Message 1 of 17
4412 Views, 16 Replies
Hi guys,
Struggling with rendering at the moment. For some reason only the sky and a grey ground appear in my images even though there is a building there to render too. the first image is what is in the camera view and the second is what the render comes out as. Any help would be much appreciated.
16 REPLIES 16
Message 2 of 17
CAMedeck
Any chance the objects, or layers they are on, are set to be non renderable?
Chris Medeck
Message 3 of 17
in reply to: CAMedeck
Thanks for the reply. There did seeem to be a lot of things that were turnt off in the layers however it didnt seem to make a difference.
in the pic below you can see the outline of the building and some double yellow lines on the road but its still completely faded.Render Blur.jpg
Message 4 of 17
Richard.Vivanco
Hi James
Check environment and effects panel, be sure to not have fog effect on it.
Then in render setup panel, check your camera shaders.  Be sure volume is off.
Good luck!
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
Message 5 of 17
CAMedeck
Hmmm... select one of the objects, right click, and choose V-Ray Properties.  In the dialog box that comes up, look in the upper right corner.  Matte object and Matte for refl/refr should both be unchecked, and the Alpha contribution should be set to 1.0.
Chris Medeck
Message 6 of 17
in reply to: Richard.Vivanco
Thanks for all the replies but still no luck Smiley Sad
Message 7 of 17
CAMedeck
Select an object that isn't showing up, do a Save Selected.  Zip up that file and post it here so we can have a look.
Chris Medeck
Message 8 of 17
When im in an orthographic view and render it comes out fine its just when i min a camera view.
Message 9 of 17
The objects are showing up, they are just very faded and it seems like the environment is in the foreground rather than the background.
Message 10 of 17
CAMedeck
Are they affecting the Alpha channel?
Chris Medeck
Message 11 of 17
I dont understand what you mean by that sorry. Im new to 3ds max.
Message 12 of 17
CAMedeck
In the render frame window, along the top, there are some colored circles; red, green, blue.  There is also one that is white and black.  Click that and it will display the Alpha Channel.  An image's alpha is transparent pixels that will show through what is behind it.
Chris Medeck
Message 13 of 17
I clicked that button and the render turnt white.
Message 14 of 17
CAMedeck
Okay, that means it IS affecting the alpha channel.
Like I asked earlier, grab an object that isn't rendering correctly (along with your camera) and do a Save Selected.  Zip up that scene and post it here so we can take a look at settings.
Chris Medeck
Message 15 of 17
Hi I am
Sort of having a same
Problem too .. Nothing appearing when I render .. Please help
Message 16 of 17
rendermaster
recheck the position of your camera, it could be that there is some object with glass material on its front
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 17 of 17
I had the same problem and solved it by un-checking the clipping option for the camera. Hope this helps anyone!
