Nodes wires are displayed incorrectly (Left - Right Inputs - Outputs)
speltospel
Message 1 of 12
speltospel
this is 2025 max
I can’t switch to 24-25 max because I don’t clearly see where the Wires of nodes come from. Is it just me who has this problem? Or are there others who are bothered by this?
Is there any work going on to fix this?
this is 2023 max
Replies (11)
Message 2 of 12
giuseppe.schiralli
Do you see this problem also with no-Corona nodes?
Would it be possible to send us that file, or a video that shows how to reproduce it?
Thank you,
Giuseppe
Giuseppe Schiralli
3ds Max - QA Analyst>
Message 3 of 12
speltospel
(view in My Videos)
x2 files for 23 and 25 max
https://drive.google.com/file/d/18yX7aDT-EOQ1ghxjzQbdw5hPCQgJ8dok/view?usp=sharing
Message 4 of 12
speltospel
I tested the same scene with a different node direction setting. Apparently testing of the new node system took place in the default settings.
I enabled the default and everything looks good.
Message 5 of 12
speltospel
Autodesk Team, so I found the problem. will this ever be fixed?
Message 6 of 12
speltospel
Hello, is there any progress on resolving this issue?
Message 7 of 12
RobH2
Seems like it could be a Corona issue. Three questions:
1. Have you looked at the Corona Forum to see if anyone else has this issue?
2. Have you uninstalled Corona, and "without reinstalling it" rebooted, and tested to see if it still happens with Max Standard materials?
3. If the answer to #2 above is "no", then reinstall Corona and see if it the problem is still there?
4. If the answer to #2 ab ove is "yes", then continue to pursue it with @giuseppe.schiralli
I don't have Corona and I couldn't reproduce it. That led me to think is a Chaos/Corona implementation issue and not a Max bug.
Rob Holmes
3ds Max (2025-2027), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Message 8 of 12
dmitry75MB6
Hey @RobH2  @giuseppe.schiralli  I know this is an older thread, but this issue has nothing to do with Corona or any plugins.
Here is my test on a fresh install of Max 2025.3 and how to reproduce it with default nodes:
1. Slate Editor > Preferences > pick Left <- Right mode , restart max
2. Create Checker Map and a Physical Material
3. Pipe Checker output into Physical Material's Base Color Map
4. Hide Physical Material's inputs by pressing "-"
Expanding all outputs generally draws things correctly, but the editor gets really cluttered if you have to open all of them.
Note that the issue seems to apply mainly to material nodes, most maps that I've tested appear ok.
Message 9 of 12
RobH2
I'm going to leave this one to @giuseppe.schiralli as he's way more qualified and connected to the dev team. I can't reproduce it though.
Rob Holmes
Message 10 of 12
dmitry75MB6
I was able to reproduce it on 3 separate machines with a fresh install of Max. I tried on both win10 and win11. Make sure you follow the steps outline in previous post
Message 11 of 12
speltospel
I tested everything on the new 3ds max 2026.
the problem is still here and it seems like no one even tried to fix it. 😢
LEFT < Right (Nodes wires are displayed incorrectly )
LEFT > Right (Nodes wires are displayed correctly 🆗)
for those who can't repeat this (for some reason) I'm attaching a 3d max file with a simple branched shader, which will clearly show the problems with the wires. if you switch the mode and reboot 3d max.
Message 12 of 12
RobH2
I see that @giuseppe.schiralli has viewed this thread. Hopefully, he can shed some insight. Have you officially reported it? If not, please do.
Here is a link to help you do that:
Bug Reports:
https://www.autodesk.com/company/contact-us/product-feedback
Rob Holmes
