Bringing in a stacked texture? AO/roughness/metallic - what node to use?
mikeluard
mikeluard
I'm doing some texturing for an Unreal video game, we're using the packed texture method where the texture file has channels containing: R - AO G - Roughness B - Metallic
What node do I need to run these through to get them understood by Max? I tried out various RGB nodes and the OSL: Bitmap Lookup (which looked like it was going to work) but can't figure this one out.
mikeluard
I tried loads of different nodes and may have got it, under: 'Maps, OSL, Math, Color components'. It seems to work.
Does anyone know if this is correct or perhaps there's a more simple way of doing it?
CiroCardoso3v
Yes, that is the correct way to do it. One image comes in, and you split the channels into different outputs.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
