3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Mental Ray Render Shadow Density
10 REPLIES 10
Message 1 of 11
1142 Views, 10 Replies
Hello
I want to increase the shade intensity in this scene but it does not
Density values does not work
You can look at the attached file to examine the scene "1.max"
10 REPLIES 10
Message 2 of 11
darawork
Try turning up the Final Gather Precision, and increasing the FG Bounces to at least 1.
You can also enable Ambient Occlusion on both materials, or render out a seperate Ambient Occlusion pass to add to the final render.
http://cgi.tutsplus.com/tutorials/three-ways-to-generate-ambient-occlusion-in-3ds-max--cms-21612
good luck 🙂
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Message 3 of 11
in reply to: darawork
Thank you very much 🙂
Message 4 of 11
I have a question again 🙂
I'm using mental ray
The reflection of light seems soft
Standart photometric lights. I do not want to disturb the position of the lights.
What can I do to make it look sharp?
Is it possible to provide it with light settings? or different method
I do not want to use this method >> self-illumination
Message 5 of 11
darawork
If you're using 'Arch&Design materials', you can make the metal material more glossy and turn the reflection value up.
100 reflect would be a mirror, 100 glossy is a perfectly smooth object.
But give it a bit of time, you'll learn this in college hopefully. 🙂
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/3DSMa...
Darawork
AutoDesk User
Message 6 of 11
darawork
http://www.mrbluesummers.com/3731/3d-tutorials/3d-studio-max-arch-design-preset-examples
Darawork
AutoDesk User
Message 7 of 11
I was disappointed 🙂
Even the most brilliant form looks soft
What would be your suggestion?
Message 8 of 11
darawork
Can you .zip and upload your scene here?
Darawork
AutoDesk User
Message 9 of 11
Message 10 of 11
darawork
Darawork
AutoDesk User
Message 11 of 11
Better than the other 🙂
Thank you very much again
