max shutting off while rendering in vray
hello
I am rendering a character animation. Whenever I try rendering in vray max shuts off with an error report. I am not sure why it is keep shutting off cause my computer is in good shape. When I render with mental ray it works all fine.
What should I check to find out the problem? And what do you recommend to fix this problem?
windows 8 x64
Intel Core i7
Ram 8.00G
NVIDIA GeForce GTX 980 Ti
thank you.
I don't use v-ray so I doubt I'll be able to help you, but someone who knows v-ray will probably need more information. A screen shot of the error is a good place to start. Did you google the error? Whats special about the scene? Particles? Plug-ins?
Dean
kgokhangurbuz
Greetings;
Can you please tell me about
-Your pc's specifications
-If any, addons you are using
-Render setup you are using (I may need your .max file to inspect this, if you are going to attach it, please save as 3ds Max 2014)
-V-Ray version and 3ds Max version
Sending me the file would help a lot really, actually.
Best regards;
