3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
material id
2 REPLIES 2
375 Views, 2 Replies
material id
hi, any idea for animating this material id I want the animated objects When colliding time to get collided objets material id is good for animating text passed through another object.
images.jfif
material id
images.jfif
Tags (1)
Labels (1)
2 REPLIES 2
CAMedeck
CAMedeck
If I understand correctly, you want the Material ID of an object to change after colliding with another object.  You could manually animated the spinner on a Material ID modifier to do this, unless you want it to be automatic.  Maybe it could be done with a particle system?  It really depends on what you are trying to do.
Chris Medeck
Chris Medeck
mad.kaveh
in reply to: CAMedeck
mad.kaveh
yes, exactly it is what I want manual solution is not good for large projects please particle solution.
