hello. the first try of rendering
second try of rendering.what's problem.how can I sovle it?pleaze help me
It is hard to say, but it kind of looks like either your objects are not fully visible, or you've reduced the opacity on the material applied which is letting you see through your walls.
What kinds of things did you change before you rendered the second image?
Chris Medeck
To me it looks like you added a metal material to the walls and you are seeing the reflection.
