Issue: Rendering using 100% of CPU - Crashing Monitors/Display
I'm currently using 3ds Max 2017 and my situation is applicable to all methods of rendering e.g. ART, mental ray, iray, etc.
I used to have an all-in-one PC, of which when I ran ART renders it worked totally fine, but ever since I upgraded to my build PC I'm having issues.
Whenever I attempt to render a frame, the CPU rockets to 100% work rate, which can cause my monitors to crash. I have no idea how to limit the amount of CPU the render process has access to, and I am unaware of any other methods of fixing this issue.
It's really annoying, as I would like to have back the nice, clean render process that I am use to, because at the moment, rendering is something that I am unable to do at all.
Please, if you have the same issue and know of a fix, I would really appreciate some extra information
irishman_team_kilber
have you configure the bios correctly? you will be able to set the temperature from there
do you have another processor unit?
do you get a monitor signal? when you Monitors/Display crashes
what verion of max & windows are you using?
is your PSU properly sitting on your CPU?
also check these answers out http://www.tomshardware.co.uk/forum/id-2394163/monitors-losing-signal-gpu-fans-speed-computer-crashe...
i don't think this is a max question really it's a computer question. i think you would need to find a computer community to answer these questions!
Francisco_Penaloza
When you render, you should use all the cores and CPUs that your computer has available at 100%. This should not crash your computer, if this is happening, there is a hardware problem.
Your Monitor is not related at all to the rendering process unless of course, you are using GPU rendering, in that case, your image should freeze or slow down the refresh rate. But that's related to Video card performance and not the actual monitor.
In any ways maybe your computer is not up to the task, your power supply may be too small for your CPU and video card, or you are just running out of RAM.
What are the specs of your Old all in one machine compared to your new machine?
You could also change the CPU priority to your software.  Fire up the task manager then go to Prosses and select 3D Max app, the do right click and choose Set Affinity, the un check one core of all the cores displayed, this will let you at least one single core to run windows.  This should ease your Windows performance, but if you are running out of RAM that's an other story.
Please post your computer specs to give you better advise.
darawork
"is your PSU properly sitting on your CPU?"
If it is, well... then, there's your problem.
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
I favor to say from the copious amount of i5 4*** CPU troubles is it the processor itself. I am now not positive if it driver trouble or bios. I am questioning if you do some simple OC it may additionally help. you can go here they may additionally have something for you https://windowserrors.org/best-cpu-temp-monitor-software/
