How can I load UDIMs into Arnold "Image" node?
TMat
Message 1 of 10
TMat
Looking at the Arnold docs for the Image node it states "UDIM token functionality is supported" but I can't figure out how to load in multiple UDIM tile maps as one can with the 3dsmax Multitile node.
Can anyone tell me how to get this to work?
Thanks in advance.
Replies (9)
Message 2 of 10
Stephen.Blair
use the <udim> token in the texture file name
S:\assets\textures\example.<udim>.exr
// Stephen Blair
// Arnold Renderer Support
Message 3 of 10
TMat
@Stephen.Blair   Thanks for your reply but this does not work.  The node will not acknowledge any more than the first UDIM file.
You are not suggesting I use "<" or ">" in the file name are you??
Message 4 of 10
Stephen.Blair
Yes.
The <udim> token will be replaced with 1001, 1002, and so on
// Stephen Blair
Message 5 of 10
TMat
So, how am I to name a file including the characters "<" or ">" ??  Windows will not accept these for use in a file.
Message 6 of 10
Stephen.Blair
You don't name the files with "<udim>"
You type "<udim>" in the filename box, in 3ds Max.
At render time, the <udim> token is replaced with the required udim number.
// Stephen Blair
Message 7 of 10
Alan_WP
@Stephen.Blair Just wondering if you could please help me. Your above statement helped when rendering locally. I am now using Backburner and have moved all files to a networked drive using UNC paths accessable to all servers. All servers are using the same version of Max and MaxToA. I have tried with the option 'include maps' and without. I recieve no errors or crashes within Backburner, just a black rendered image completed in a fraction of the time.
Any ideas?
Message 8 of 10
Stephen.Blair
That doesn't sound like a texture udim problem. Can you get a detailed Arnold log for a render?
// Stephen Blair
Message 9 of 10
lauri_barnhart
Hi @Alan_WP,
I wanted to check in and see if you saw @Stephen.Blair's follow up question and if assistance is still needed or if you found a solution to your question already? Please share any available information so the community can assist you further.
All the best,
Lauri | Community Manager
Message 10 of 10
Alan_WP
Hi Stephen,
you are absolutely correct. Our administrator updated the MaxToA but didn't update the Nvidia driver. After turning on generate logs, the error message was clear.
