3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
GPU rending details
5 REPLIES 5
484 Views, 5 Replies
GPU rending details
I'm attempting to use GPU rendering for a project to save some render time. I see that the sample settings get grayed out and just the camera sample settings are available. I understand this and have adjusted my settings to get a pretty clean noise free result... but the render is much darker. I'm messing with exposure control but not having a lot of luck. Am I missing something obvious?
Frank
Labels (1)
5 REPLIES 5
jostroopers
Hi Frank
Look at this tutorial from Ciro Cardoso
https://youtu.be/dsJ7B5lb-C8
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
CiroCardoso3v
And have a look here
https://docs.arnoldrenderer.com/display/A5AF3DSUG/Getting+Started+with+Arnold+GPU#GettingStartedwith...
When in GPU you control the quality with the Camera AA Max and Noise Threshold.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
CreativeFRV
in reply to: jostroopers
Thank you very much for that! I'll check it out. I ended up signing up with Rebus Render Farms, the rates are reasonable and my scene renders so much faster... something I should have done long ago!
Frank
CreativeFRV
in reply to: CiroCardoso3v
Thank you!
CreativeFRV
Wow that tutorial was good, so informative. I immediately subscribed to his channel... One of the problems of not working in a studio with lot's of animators is the lack of brillant 3d artists to collaborate with. Thanks very much for the share.
