3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Filling up spline
4 REPLIES 4
14464 Views, 4 Replies
Filling up spline
Hi
I am trying to create a decorative hinge. The basic shape was created with splines. And then I extruded it. But as you can see in the attachment; its hollow. How do I fill it? This is 3ds max. Thank you
4 REPLIES 4
PROH
Hi. The extrude modifier can only cap shapes if they are closed (all vertices are welded together). So make sure you spline is closed, and that "cap" is checked for both top and bottom in the modifier.
Hope it helps
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
in reply to: PROH
Thank you so much! It worked :))
in reply to: PROH
Really solved my problem...thank u Bro
kritishrivastav
in reply to: PROH
Thank you so much. It solved my problem as well.
