Hi
I am trying to create a decorative hinge. The basic shape was created with splines. And then I extruded it. But as you can see in the attachment; its hollow. How do I fill it? This is 3ds max. Thank you
Solved by PROH. Go to Solution.
Hi. The extrude modifier can only cap shapes if they are closed (all vertices are welded together). So make sure you spline is closed, and that "cap" is checked for both top and bottom in the modifier.
Hope it helps
