3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Diffuse and bump map not showing in preview on material editor
4 REPLIES 4
1968 Views, 4 Replies
Hello!
I recently installed 3dsmax 2017 with Vray 3.4.
The materials I create are rendering well and showing in viewport; but not in the material editor.
Can anyone help me?
Thank you
4 REPLIES 4
Richard.Vivanco
Check if the option use real world scale is disable in all bitmaps.
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
rendermaster
try using  another material if it will looks the same on your material preview window, just to check if it is on material settings/parameters or on the material that you used...
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
in reply to: Richard.Vivanco
Yes! Is disable, I already tried it.
Thank you for your suggestion, worked for me! c:
Technology Administrators
