Hello!
I recently installed 3dsmax 2017 with Vray 3.4.
The materials I create are rendering well and showing in viewport; but not in the material editor.
Can anyone help me?
Thank you
try using another material if it will looks the same on your material preview window, just to check if it is on material settings/parameters or on the material that you used...
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
