Hello, I'm relatively new with 3ds Max and Vray. I watched few tutorials about Vray rt which should be located under the active shade but I couldn't find it. Is it located in different place or named differently in current version (Vray Next update1 and 3dsmax 2019.3) ? Or is there some other way to render using both CPU and GPU?
Solved by miledrizk. Go to Solution.
I don't use Vray Next, but I think you need to look for V-Ray GPU Next
Instead of V-Ray RT.
