3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
3ds Max 2016 rendering results changes while rendering
2 REPLIES 2
368 Views, 2 Replies
Hi
Using mr, the render results are changing while rendering a sequence.
frame 0542 has a burnt look, it should look like frame 0541.
Re-rendering the same sequence will give different results -  different frames will have the "burnt" look. The same happens after restarting max and restarting the computer
Happened while rendering other projects too.
Help will be much appreciated.
2 REPLIES 2
Francisco_Penaloza
Are you using FG or GI??
if this is an animation are you pre-calculating, saving and loading your FG or GI??
in reply to: Francisco_Penaloza
Thank you Francisco
It is an animation. FG turned off.
It happens with different files.
Any ideas?
Thanks again
