Composite Map does not always display the textures correctly when being displayed through the Material. But that is only on the viewport preview, the true test is if it renders correctly. You can set the Bitmap to be visible in the viewport instead of at the Material level if you want that texture map to be seen in the viewport correctly, but it will not display any other maps or effects in the material.
Chris Medeck
![EESignature EESignature](http://autodesk.i.lithium.com/t5/image/serverpage/image-id/1272565i464DC3DC646B4F11/image-size/original)
