3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Composite map
1 REPLY 1
markoD4MXL
248 Views, 1 Reply
Composite map
Hi!
I am trying to use composite map to create a material.
When vraybitmap applied to difuse chanel of the shader mapping is ok, but when I try to use this map thorugh composite map something happens with size of the map.
1 REPLY 1
CAMedeck
in reply to: markoD4MXL
Composite Map does not always display the textures correctly when being displayed through the Material.  But that is only on the viewport preview, the true test is if it renders correctly.  You can set the Bitmap to be visible in the viewport instead of at the Material level if you want that texture map to be seen in the viewport correctly, but it will not display any other maps or effects in the material.
Chris Medeck
