Hi everyone! I am having a problem and I hope someone can help me.
What I have:
1. Multi-object Turret model.
2. Four sets of unwrapped textures for said model, each with base color, height, normal, emmisive, roughness and metallic maps.
3. A pair of crooked hands 🙂
I need to combine all sets of maps into one set. So that at the output I get one base color, one height, one normal, one emmisive, one roughness and one metallic.
I was able to redistribute and pack UVW islands in a new channel and even tried to bake textures, but then a problem appeared: the rendered maps are very different from the original ones. They have a different hue, rough heights and normals, and so on. So my question is this: How to bake maps without these changes? I suspect that new maps are generated anew rather than compiled from old ones. So is it possible to somehow preserve the original quality of the maps or Max will redo everything in his own way?
I hope I have explained it clearly. If not, please ask questions. I will be glad for any help.
What I have:
Solved by oliver. Go to Solution.
Just to make sure:
I did some tests just now and besides some anti-aliasing differences all my baked maps look exactly like the input maps (color-hue, normals, ...).
Just to make sure:
Thanks for your reply! Well I'm pretty sure that I applied override to 1. But I'll double check that to be sure. Thanks again.
I did find a problem and it was on my end. It was simple "forgot to save changes" thing. I set gamma to 1 and it all worked like a charm. Thanks again for sorting this out.
