3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
ART renderer PBR Material not compatible with Multi/Sub-Object Material
1 REPLY 1
markus.langseth
500 Views, 1 Reply
Hi
I've been trying to use PBR Material with the Multi/Sub-Object Material with no success.
I just get a message telling me that the material is not supported bla bla bla, but in the note on the PBR material it says it is a modified version of the Physical material which works just fin in the ART renderer.
PBR materials work just fine on their own in ART.
Is it just not compatible?
1 REPLY 1
jon.bell
in reply to: markus.langseth
Hi @markus.langseth,
Thanks for your question! I just tested this in 3ds Max 2021.3, and a multi/sub-object material with 3 different PBR materials loaded into each slot rendered fine with ART.
Can you please confirm that you used the Customize > Custom Defaults Switcher to change your Max settings to be ART-specific? Or did you just change to the ART renderer in the Rendering > Render Setup menu? (If so, I'm wondering if the PBR materials that you load then are still Arnold-centric.)
Please let us know, and we hope to hear from you soon!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
