3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Arnold "specular_roughness" not working help!?
2 REPLIES 2
Fahad_ALAsmari
315 Views, 2 Replies
Guys I need some help why is the "specular_roughness" isn't working at all I can't even see any single change to the material roughness at all.
Tags (1)
Labels (1)
2 REPLIES 2
wernienst
in reply to: Fahad_ALAsmari
There are several causes possible.
First, specular should be at 1.0 and specular_color should be white.
In the Range node, output_min should be at 0.0, output_max at 1.0 and input_max greater than input_min, depending on the Bitmap.
In the Triplanar node, try Coordinate Space = object and different Scale values. Important: the smaller the values, the greater the tiles.
Fahad_ALAsmari
in reply to: wernienst
I made a big mistake which is adding these files and applying sRGB not opeing it as RAW file so yeah problem solved, anyways Thank you.
Technology Administrators
